Alteran
Tachymetric Relay
Alteran
Hello everyone.
Could anyone please tell me how many pins the tachymetric relay has? I have a 1.6 Gti, 1990 model. Strangly there is a four pin relay plugged into a seven pinned plug near my ECU. My car will not start after i have removed the immobiliser and soldered all the wires back to standard.
Something tells me that when an immobiliser is fitted, the proper Tachy Relay is substituted for a simpler Relay.
Any info would be great.
Thanks in advance
Liam.
5 normal sized spades, and 2 half sized ones, 7 in total.
Alteran
Thanks for the quick response Baz. I need to source one of these then! I've heard they're pretty expensive from Peugeot, Anybody have one lying about on the off chance?
Moz_Goodwood
they are expensive from peugeot try ebay they're usually on there from £10 to £20
Alteran
Thanks Moz. There is a Vauxhall one on there for 13 quid, I wonder if they're the same?
If the Vauxhall one is the same as the one I have here its got one less small pin.
Alteran
The eBay ad does say 7 pin but you never know with these things. I think i'm going to hold out and get the correct relay. Thanks for everyones replies.
Liam.
