Matteo
Valve Cover Painting
Matteo
Hello, just a silly question. I am going to paint in glossy black color the valve cover (XU9JA). Have I to use a special paint for high temperature or will a common paint do the work?
Many thanks.
Mark205
Take into consideration to use some acid etch primer first.
I painted my rocker cover in hammerite smooth red and thats faired ok. B)
Matteo
I was thinking about washing it with polyuretanic thinner (degreasing), dry it well and then spray it with a common acrylic glossy black paint.
Have I to use a special paint for high temperature?
Mark205
Well i wouldnt have thought so as my rocker cover has faired well.
The rocker cover is alloy/aluminium so use an acid etch primer first otherwise the paint won't stick, (it will initially, but then will flake off easily).
You don't have to use a special paint, normal paint will do, but thats your choice.
Matteo
I made the job :lol: . It seems nice. I warmed it after painting and it seems ok.
Mark205
Looks good, but unless you put that etch primer on it, it won't look like that in a couple of months use.
hexhamstu
Matteo
Usually I am rather touchy.
I bought and used a primer for alluminium alloy.
Mark, thank' s for your advice.
Mark205
No problem, i have a friend who owns a body shop and i got the same advice when painting mine.
