dimmapalmer
What The Hell Gearbox Is This?!
dimmapalmer
Apparently its a 1.6
Is it boll*cks :D
theres no filler hole in the side so i have no idea how much oil to put in, just stuck with 2 litres.
pretty much everthing else is the same.
at 70mph its at 3k revs, and the gears all seem realy long.
Other than that its identical to my 1.9 (which possibly was a 1.6 already <_< )
I'm thinking diesel box.
Any ideas?
cheers
Another thing, will it be easy to put the diff into my other box? It has new bearings on and everything (fitted by gearbox rebuilder company)
be1's didn't have the level plug on the end casing.
err, mine does, but it is 1989.
that's a BE3 pictured.
are there any i.d stickers at all?
check for the date stamps.
dimmapalmer
its a lift up reverse same as my old box.
ill look for any stamps.
gears are just reaaaly long.
Ryan
If you got it from a breakers then chances are they've just given you any old BE gearbox, as they don't care about things like ratios as long as it fits.
dimmapalmer
the diff should be easy to put back into my old box then? will the bearings need changing again?
changing the diff wont gain you anything (unless its an LSD)
Early BE box's did not have the hole in the end casing but had plug's in other places depending on the year as they all varied allot, But sounds like a Derv box as these where made from 1984 ish
