johnnyboy666
Be-ma Gearbox Info
johnnyboy666
ive heard quite a few people mention the BE-MA gearbox that will fit TU engines, and im interested in doing this myself. i'd like to know who has done it and what else needs changing or adapting to make them fit?
im sure ive seen somebody's project on here that had this conversion but i cant remember who it was :D
so far ive found that the box is from Picasso, C4 and 307's im assuming all 1.6? are these all identical boxes or is there a preferred one to go for?
will the gear post pivot thing need to be moved ?
can the same gear rods be used?
will it need 1.6gti driveshafts?
if anbody has done this and could post a step by step type thing and a list of parts or something the that would be excellent :unsure:
thanks in advance
john
decoc182
From the bits Ive gathered together you will need a XU suframe, XU driveshafts, XU intermediate bearing carrier and the bits to work the clutch and gearchange.
Picasso,307 and c4 1.6 have the gearbox
burr_2000
Whats the weight difference between a standard MA box and this BE Box?
jonnygoodhand
Not a great deal, I think. The above gearbox weighed around 32kgs, all crated up, when new from citroen IIRC.
