phil-83
Radiator Fans
phil-83
hey all, i was just wondering if any one knew what the radaitor fan size and dimesions are ?
Garry
What is it you are trying to do?
As standard they part of a rather large plastic mounting that has room for two fans, but Gti's only run 1 fan, is it that what you are after?
The actaul fan blades are quite small 8-10'' or so.
phil-83
well im runnin mi16 engine and was lookin at extra cooling, ive found me self 306 d turbo twin fan and its plastic housing would that fit where the old fan would have been ?
The standard 205 cooling system is fine for running a Mi when its all in good condition.
Twin fans don't give any extra cooling because they are only working when the car is at a high enough temperature to trigger the fan switch in the rad.
205 diesels have twin fans & the same radiator cowling as the GTi so they are a direct fit, albeit un-necessarily.
Graham.
phil-83
well wen sittin in traffic it get very hot, i was gonna run 1 fan off a direct power lead and swicth, this work on a friends 2.0ltr fez turbo
Cameron
How quickly does it get hot? If it happens very quickly then something is definitely wrong, especially in this weather.
phil-83
normally drivin its fine, but i was sat on the m6, in traffic for just under a hour the other day and it was close to the max
Edited by phil-83
MerlinGTI
if you still have the orginal copper raidiator id ditch it and buy a nissens alloy one + Thermostat + cooling system flush.
I say this as every single copper 205 rad ive seen has been near death ( Copper (rad) and alloy (engine) dont like playing together when you throw water and heat into the mix.) Nissens alloy ones are only £50. When I first bought imy car it overheated on the way home, By doing the above things it never goes significantly above half way :lol:
Alfie
My Rad is a bit beat up too. I reckon to replace it well before the summer. Where can I obtain one of these Alloy ones please?
Pretty much any motor factors imo or ebay if you have to resort to it.
Should be able to find them for around £40 locally imo.
Graham.
MerlinGTI
Go for a Nissens one though, the quality is brilliant.
I fit rads everyday, pattern parts & OE for every make of car and I was impressed when I opened up my Nissens one <_< Still looking like new 2 years later if not a little grubby.
