Moz_Goodwood
Engine Mounts
Moz_Goodwood
hi all, im moving house soon and need the 309 to be towed away seeing as it has no engine at the moment, i do have the 2.0 turbo lump ready to go in but the conversion wont be ready in time
i was wandering would just the top and bottom engine mount be ok to hold the engine for transport? as i wont have a gearbox to use that mount or will it put to much strain on the others???
i only ask as it will save me a trip shifting the engine and if im paying for the car to be trailered anyway
wont work :lol: you could leave the rear mount off, but not the transmission one.
Moz_Goodwood
bar-steward thought as much
ive still got my old 1.9 gti gearbox will that fit just so i can use it for transport?
if it does fit my next question will be would it be any good for the conversion, gear ratios, torque handling ability etc
cheers
paul
yup that'll do the trick, don't even need a flywheel in there just bolt the box on, can't say for certain on the actual ratios for use with the turbo, but I should imagine it being more suited than a 1.9 box.
plenty of conversion threads to check up on :lol:
Moz_Goodwood
thanks for that mate
ive read every turbo project going now four or five times over, but im a sod for just looking / remembering the bits i need at the time if you catch my drift :lol:
i'll have another trawl in a bit
cheers
paul
omega
if u have a strut brace fitted you could but a rachet strap round the engine on to the strutbrace then this would support it
platty
Don't forget to bolt in the driveshaft's in or it'll end in tears :)
I pulled a bearing out just by pushing my old 205 in and out of the garage with no driveshafts in!
