205freak
Best Injector For A 1.6?
205freak
i would like to know what´s the best upgrade injector to use and where to buy, i´m looking for one´s with a debit around 200cc... i know that the most common is to use the 1.9!!!
What about the gr A black one´s from peugeot????
Any help is welcome!!!
ORB
Have you upgraded the engine in any major way? if not, stick with the blue 1.6 ones as any other will just over fuel.
As said, Also there's no Group A Peugeot one which I guess you've seen on ebay, these are std 306 2.0 8v XSi injectors which can be had for nothing and don;t flow as much as the std 1.9 one.
205freak
I was just asking cause i rebuilding an engine that i´ve bought a few weeks ago, so just looking for some nice upgrade on the fuel injection department!!!
So i better off with 1.9 one´s!!!
hexhamstu
no. you are better off with the standard blue 1.6 ones. unless you have throttle bodies and management the 1.9 injectors will make the engine over fuel.
j_turnell
As above pointless unless your going for serious power where you'd actually require bigger injectors.
large
Again if you are not uprating anything in the engine i would stick with the blue 1.6 ones. Don't be taken in by adds saying fit this part and get 10,20,bhp, it does not work like that.
