Cloverleaf
[trackday_prep] 309 Trackday Car
Cloverleaf
I thought it was about time I started a project thread so here goes…
Bought my 309 off ebay for £500 with 112k miles on the clock about 15 months ago, had a long MOT, and full history and came with 2 sets of alloys with good tyres. Only mod’s were an induction kit, exhaust and it’s lowered on some unknown springs. The only bad point is the o/s front wing and bonnet appear to have been painted in the Sahara desert! This textured finish didn’t bother me as the car was going to be a cheap track car.
So as soon as I got it home I removed all of the interior.
Next I fitted some Cobra bucket seats I had and some Sparco harnesses, some Brembo max discs, mintex 1155 brake pads and super dot 4 fluid and gave it a full service: cambelt, water pump, plugs, leads etc.
I then took it to the French car show and took it around Rockingham for 30 minutes during which time it performed brilliantly.
Although the car was supposed to stay standard(ish) I purchased a 4-1 manifold from ebay and fitted that. I was then booked onto a track day at Donnington, however on the way there the head gasket went.
After a lot of thought a decided to go for an Mi16 engine and found one on ebay with most of the things needed for the conversion. I completed the conversion about August last year, including re-freshing the engine with new big ends, water pump, cambelt kit, valve stem seams. I used the Mi management and fitted a 205 oil cooler. I made my own baffle for the sump and remounted my seats on weld in rails. During the time it took to complete the conversion the beam seized on one side – more on this later.
Cloverleaf
I trailered the car to Donnington for a track day in August last year (with a seized rear beam). The car had only ever idled on my drive before then so I was expecting trouble. The first session I took fairly easy and was surprised at the difference in performance compared to the 1.9 8v. The only issues I had all day were an intermittent misfire, which I later tracked down to a dodgy connection on the ignition module just before the last session, and a split coolant hose which I cut the end off and re-fitted.
I was now beginning to see some real potential in the car so thought I better turn it into a proper track car. Hence, phase II began with the aim of fitting a cage, sorting the suspension and possibly upgrading the brakes.
So….I have brought a CL3 cage from custom cages and 15m of 38x1.6mm T45 tube. I am going to base the cage on the custom cages multipoint design linked to front and rear suspension with a few little changes. For the suspension I am going to do the rear first then the front later. After stripping my beam I realised the one trailing arm pin was scrap. After looking around for another 309 beam I realised they are very expensive and there is no guarantee they are serviceable due to the age so I thought I’d try something different and fit a 306 beam. So I got one off ebay from a 65k miles Gti-6.
I mocked it up under the 309 to see how much wider it is…
It’s about 40mm or so and the only problem I can see (apart from possibly having to roll the arches) is the strengthening plate that runs along the car linking the cross rails – it’s just too narrow so will require cutting, more on this later…..
I then stated stripping it…clean splines…
I plan to use the same mounting points in the car and fabricate some new beam mounts so I can swap back to 309 beam if I want to. The rear mount is simple but the front mount I plan to cut up part of the 306 mount and weld something to it….
Now I’ve planned the mounts its time to clean up…lick of paint on the cross tube and TB’s…
In the meantime, I stated on the rear beam mount. I had some top hats turned up…
Edited by Cloverleaf
Cloverleaf
These will be welded into some T45…(note cut out in boot floor around rear beam mounts)
And cut out a cage foot….
I then started to grind out the rear strengthening plates…
That’s it for now but there’s plenty to do…..
Joe
Craigo
looks good mate, keep it up!!
Good work, great to see another loved 309, very ambitious with the 306 beam there, will be interested to see how it comes out! :)
edbar
Agree with Baz! Great to see anouther 309 and intresting project with the rear beam! Keep it up. :)
how much wider is it? do the bumpstops still line up?
allanallen
Cloverleaf
Thanks guys. Yea it's about 40mm give or take a few mm (I measured it quickly). Not sure the bump stops will line up TBH.
I'm hoping to finish the beam mounts and get the rear cage mounts welded in this weekend so I'll see what else I need to do regarding the beam then. Then I'll take the 309 beam off and clean up the underside of the car.
Cloverleaf
Did a bit more today....
Sunroof removed:
Rear cross members stitch welded:
Used the ruined 309 cross tube as a jig and welded the rear cage mounts in (TIG in the inside, MIG in the outside):
Cut the bump stop out (needs to be wider) and seam welded - was nasty under there so it's not pretty. Will tidy it up tho and build a new mount for the bump stop:
That's it for now
edbar
Good progress, keep it up, will be fitting my cage soon aswell! :(
Cloverleaf
Another Sunday - a bit more work.
Half finished the rear beam mounts (no pics - too boring!). Will offer them up to the car then finish them.
Removed the pedal box/master cyl/servo. Going to make my own bias box. Also ground off the bulkhead strengthening bit so I can fit my servo strengthening plate on the inside...
Drilled some holes (51mm) in my inner sill so I can slide my cage in to weld the top...
Main roll hoop somewhere near where it will go (it will be tight to the roof obviously)...
Took the wing off and ground a bit of the inner wing off so I can weld the strut top strengthening plate in (I think it's slightly different to a 205 here where the inner wing is curved around the strut top?!)...
Also picked these up, they're much bigger than I thought! I'll offer them up and see if I can make them fit and still keep 15s!
I also removed the heater matrix and fan and removed all the sound deadening from behind before refitting it.
More tomorrow....
Craigo
nice one mate, brakes look awesome, just grind off the GAY MG!!
Cloverleaf
Looking at it today, I think the brakes might be a no go! But I'm not giving up just yet...
Finished cleaning up the underside and etch primed it....
Fitted the servo strengthening plate ready to be welded in....
Also got both the strut top plates ready to weld, cleaned off the paint etc.
Next job is to fit the rear beam and then can start on the cage properly.
CosKev
Nice work :mellow:
Be a proper track beast :mellow:
Just one thing,does it run ok with the AFM like that??????Had mine tuned and was told the AFM should be as near as possible to flat,cause the weight of the flap comes into play and can cause probs :(
Cloverleaf
It seems to run fine although I'm going to move it as I plan to make an air box and relocate the battery. Never thought about it really. I suppose it would be more significant at idle but I don't let it idle on track much :(
Cloverleaf
The only thing about Custom Cages is I'm not very impressed with the cage feet that come with it. Coupled with the fact that I've got big holes in my sill now :lol: I made some better ones.
Custom cages on the left, mine on the right...
And in place....
B pillar...
A Pillar...
Hope to start doing the cage on Sunday B)
edbar
Great stuff, coming along now. Im going to make my own foot plates for the cage aswell. Looking good so far.
Cloverleaf
Finally finished the rear beam mounts - I just really hope it's central and straight! I tacked them on the car and then removed them to finish them. Just need some paint now. I can alse build the beam back up now. I'm really excited to see how it sits...
Welded the strut top plates and a quick bit of primer to stop them rusting...
And the pedal box plate...
Also received my bias bar and dash adjuster from rally design.
Sandy
I've got a set of those MG calipers, you'll have fun making them fit,they are annoyingly close but no cigar.
Cloverleaf
I think you're right Sandy, i've scratched my head a lot and researched about every Peugeot disc but I don't think I can fit them. Not without machining them and even then I think I might need a 305mm disc. Might have to ebay them and go down the tried and tested V6 brembo route. Disappointing.
Sandy
Sadly I think that might be the best way.
BackStreetRacecars
loving the prgogress with this.... cant wait to see it.... makes me miss my 309 more and more.....
Cloverleaf
Had a day off today so started on the cage properly.
Tacked all the front (except the strut triangulation) and the rear brace bars, and one rear diagonal. Dropped it down and fully welded it. Got it back in the correct place ready to weld in. Will do that, the other rear diagonal, the harness bars and the door bars tomorrow on my other day off :blink:
