marksorrento205
Ride Height
marksorrento205
A very quick question. It has been said on here that the rear should sit 10mm higher than the front. What is an accurate way of measuring it? The front is std height and I want to get the rear spot on. The rear has uprated torsion bars so I would guess the std between damper bolt measurement would be wrong as there should not be as much flex in the torsion bar? I just need an idea where the best place to measure it from, floor to car. Not the arches as they are not fixed so to speak.
large
Jacking points.
marksorrento205
Cheers I thought that myself but wanted someone to comfirm it.
