claypole1360
Door Hinges.
claypole1360
Hi,
both my doors on my 1.9 gti drop when opened, how hard is it to fix?
Claypole
Rom
The pins wear, which arent too hard or exspensive.
But the holes the pins sit in can wear too i think. Id start with some new pins from Peugeot, needs a special type of tool to fit. Can get in halfords etc for about £15 quid.
Pins were a £1 or so when i got mine.
When its sorted, dont let anyone lean on your doors !
toddydal
my mates door had a lot of movement on his door,1st thing i said was it needs new hinge pins but on closer inspection his door was rotton at the bottom of the door were the hinge bolts to the door is so i just plated it and now its fine,on my peugeot the bottom hinge pin could do with being done so i looked on ebay and they wanted a tenner,,,,i thought fukc that the robben twts
CosKev
Good info :)
Don't suppose you know the part number for the striker bolt please????
Mines worn threw the plastic cover part and the door lock rattles on the striker on occasions :blush:
