SPGTi
What Is Missing
SPGTi
What is missing from here ?
cheers
Steve
snooks
Throttle Position Sensor I think...
MAP sensor IIRC :)
TPS is on the other side of the throttle body...
snooks
It had to be one of the two...
yep, Map sensor :)
SPGTi
  Anthony said:
MAP sensor IIRC :)
Is there a part number as I cannot find it on service box.
cheers
Steve
Super Josh
Be aware thet there are two different types, depends on if the loom/ECU is from an early or late car.
Josh
as Josh mentioned, check which plug you have, earlier engines/looms had a normal 3 pin JPT plug, later ones had a 3 pin magneti superseal plug.
1920 9H SENSOR BOSCH - INJECTION XU10J4RS UNTIL RPO No. 08056 77.83 GBP
1920 AN - INJECTION XU10J4RS SINCE RPO No. 08057 31.53 GBP
Edited by welshpug
SPGTi
Thanks, I have one in my box of bits. I wondered what it was for, never thought about trying it in that hole.
I will be using DTA so will probably just use it to bung the hole up.
thanks
Steve
depends if the DTA system you're using wants a MAP signal or not.
