Jakob
Xu10j2 Head Vs. Xu10j2te Head
Jakob
XU10J2 head vs. XU10J2TE
Are they different in any way??
Ex port diameter?
Valve diameters?
CR?
Etc..?
/Jakob
on servicebox they are the same part number 0200 F3 up to RPO No. 07482, where there is a different part number for the turbo head introduced, 0200 V0
Jakob
Ok, thanks for info, but that dosnt give me much..
Are the turbo head the same up to a certain year / number or how should it be understood??
I am particular qurious about whether the exaust port are the same diameter....hmm
yes :)
Jakob
Well I am then not any further in my question :ph34r:
Can some one inform me whether they know of any diffrencies??
Or at best, measure an exhaust outlet hole on a XU10J2TE (Turbo) head. That would help!!!
Thanks Jakob
Hilgie
I have seen several XU10J2 and XU10J2TE heads next to each other and they were all identical. No differences in portsizes, valves sizes etc whatsoever. The camshaft is different though.
Michael
The ex-valves are different too. The turbo ones are made from a more heat resistant material than the XSI ones . But the heads are absolutely identical. I used a XSI head on my turbo engine due to very corroded waterways in the original turbo head and putted the valvetrain from the turbo head in it.
Best regards
Michael
