markw
1.6 Front Hub
markw
will the front hub flanges (the bit you bolt your wheel to)from a 1.6 fit onto a 1.9 hub and bearing.
i know the 1.9 has a larger diameter wheel bearing but was hoping that the internal diameter of the 2 wheel bearings were
the same is this right
MerlinGTI
Im intrested in this also.
I aquired 2x brand new OE 1.6 hub faces which have been fitted. As I intend on changing to 1.9 drive shafts and hub knuckles soon (for stronger shafts and more brake options) I would like to use the new hub faces with this setup rather than using some old jankie seccy hand ones.
I haven't got a 1600 one to hand to compare, but I don't think they are the same, I think the 1600 is smaller. Easy way to check would be go on servicebox and compare part numbers.
EdCherry
Cant get some piccy's up if you need them, got 2 1600 hubs sitting next to me.
