dk73
Pulling Out Dents
dk73
has any one used this method to get dents out?
heat the area using a hairdryer for 2 mins, with the co2 spray around the dent then into the dent for 30 secs. (THE CAN MUST BE UPSIDE DOWN). leave until the ice is evaporated then wipe, the dent will be gone or not as bad. if its still there but not as bad repeat process. it wont harm the paintwork at all. great for flat panels ie wings, doors, boot etc.
chrisj21
Should this not be in Body, interior & ICE section?
dk73
sorry new to here.
Gentrix
I once tried it, but wasn´t that impressed with the results - maybe the dent was to sharp. Could work well on easy ones.
andi
dk73
its better for the dents that dont have a crease in.
maturin23
Have you actually tried this out?
I've seen the videos on Youtube, but also seen loads of comments saying it basically doesn't work.
Be interested if you've got actual experience of making this happen.
dk73
yeh i've got experience of it, im a professional valeter and also dent removal specialist. its worked for me in most cases.
Topic moved into correct section.
Please have a read of this topic with regards to posting your topics.
Did you neot read the pm I sent you yesterday after you posted your engien wanted add?
Graham.
dk73
hi,im a new member,sorry trying to get used to it,can you tell me how i can get into the wanted section as ive trid and need to post 30 posts outside 72 hours,i still need to look for an engine,regards.
omega
how do you buy co2 apart from a fire extinguisher
dk73
ok,go to your local plumbers merchant they have it,its about 12 quid,hope that helps.its called freeze spray[co2 or called carbon diaoxide].
can you tell me how i can get into the wanted section as ive trid and need to post 30 posts outside 72 hours.
By making 30 posts but that doesn't include knowingly breaking the forum rules by posting your wanted topic in a section before you have made the 30 posts.
Your original topic is in the wanted section because I moved it there yesterday after you posted it inthe question, comments & suggestion section.
Graham.
dk73
ok,thanks i wont do it again....
