johnnyboy666
Quick Carb Question, Cutting Out When Accelerating
johnnyboy666
as many of you may know, my roland garros was rear ended a little while ago and looks as if its going to be written off, so with my plan of buying it back and fixing it myself, i thought i'd get a little something to use in the mean time: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=140295574734
and for the princely sum of £86.27 and only 90k miles i thought this was worth a punt :) only problem is, it apparently has a carb fault making it cut out when you apply the throttle, but ticks over fine. so i'm immediately thinking the main jet just needs a clean, but then i remembered my friends gt having the same problem and after swapping the carb it still wasnt solved, so is there a possibility that it is ignition related? any help would be appreciated greatly as always
john
djinuk
ignition coil mate, possibly, my gti did this, which i know isnt a carb but same symptoms
johnnyboy666
well im gonna take a spare carb with me just in case , and i'll see if i can scrounge an ignition coil of my mate to take with me as well, anything else worth thinking about taking?
BERTMAN
my GT had the same problems, turned out to be a very clogged fuel filter... could be a possibility
Edited by BERTMAN
AdamP
A good service (dizzy cap, rotor, leads, oil change, filters, carb clean etc) should see it right i would have thought.
johnnyboy666
i will have to make do with a basic clean of all these as im getting the train down after i finnish uni (1 oclock ish) about 2 hours on the train, then ive gotta fix it before it gets dark, could be quite an amusing excursion lol.
