DRTDVL
Throttle Body Mods
DRTDVL
Hi,
I know my friends running the misty mivec (1.6 high reving thing) get good gains from oversizing the throttle body and smoothing out the butterfly.
Standard throttle is on the right.
Would something like this be benifical to the mi16 throttle body?
Not amazingly IMO no. Although i do have one.
Well, semi-std Mi16.
Juts dug out a pic;
I wouldn't tbh for the money they are, can't remember how or where mine came from but i wouldn't pay what i've seen them for sale for.
mrswampy
I also run one on my s16
cant say what differance it made as it was fitted in conjunction with a modified inlet manifold
ptfe inlet gasket and group a decat
EdCherry
  mrswampy said:
group a decat
How can it be a Group A decat, surely a decat is a decat is a decat?
Batfink
maybe its made out of mild steel?
mrswampy
On the 306 there are two types of decat
group n which is a single tube item, much like a standerd 205 gti downpipe with a divider in it
group a is a twin tube affair, these are very hard to get hold of either new or 2nd hand.
both are shown on the peugeot boutique website
brumster
I enthusiastically did this mod on the 1.75" SU carb on my first ever car, an MG Metro ;) after reading David Vizards' "Tuning the A-Series" guide and figuring it was one of the few things I could do for free.
Obviously coupled with zero other modification on a 1275cc 4-potter, it made bugger all difference. But if you're at the other end of the scale and after every last oodle of flow I guess it's an easy mod to do. But I wouldn't bother on a standard engine unless you're just bored one Sunday!
nick
Dave Walker did an article a few years back on this but with carbs. There was absolutely no gains at all on the flowbench to the point that he even took the butterfly and spindle out completely and still gained nothing!!
Nick
Henry Yorke
Wasn't the old Mi trick to add a VAG VR6 throttle body instead for better flow, or did that prove to be another cyberspace myth?!
DRTDVL
Really?
Ohhhh would love to know if thats possible?
Do you need to change anything else?
Henry 1.9GTi
ive got the VAG throttle body on mine, I don't think they come from the vr6 though. But seems to go straight on, throttle cable is a bit tricky to fit.
I can't see the point in tb mods if still using an AFM, not sure on frontal area but would be the first thing to ditch. Seems like a lot of effort for no gain :P
Fit ITBs or force the air in :huh:
