allanallen
Difference Between Wings
allanallen
Just trying to get hold of a new wing for my phase 1.5 gti but it seems you cant get them anymore (part no. 7840 A1) however phase 2 wings (part no. 7840 A2) are still available. Anyone know the differences??
jimistdt
Is it not just the Side Repeater?
allanallen
both wings have side repeater holes. or do you mean the position or hole shape?
jimistdt
I think its the size of the holes. HERE
allanallen
cheers buddy, that clears that one up anyway. Still irritating that peugeot felt the need to make minor changes like this :ph34r:
they are positioned differently, the hole is the same though I think.
allanallen
Ahh, I'll have to get off my arse and make some measurements to see how different they are. cheers all
Rom
If your changing both it wont matter.
Ive just found this out, i needed a new NS wing, bodyshop ordered it etc, then rang me to say the hole is further forward than mine. Its the only ones available now apparently.
I stumped up for another to match the otherside.
Not been down to check it out, but they said the hole is roughly the width of the hole again infront, towards the arch...if that makes sense. So maybe 1.5 inch or however wide the indicator is.
Paintguy
Correct. One is further away from the edge of the door than the other.
Christ knows why they felt the need to change it, but that's Pug for ya :unsure:
allanallen
I was trying to avoid this as the off-side wing is mint and original so i didn't want to disturb it
SurGie
Christ knows why they felt the need to change it, but that's Pug for ya :)
It makes the car look more in perportion and it makes it look alot better, bang in the middle
of the edge to the arch, much better. The ph2 cost 150 from pug new..
steve@cornwall
Aren't ph 1.5 and 2 wings the same? Ithought early ph1 had no repeaters, later ph1 (some c, d, e reg) had the repeaters closer to the door and ph1.5 / 2 in the more central position, with ph 2 also having larger lenses
I've got a G reg shell, and one wing off a J, they're different, DOH!
Rom
Mines a phase 1.5 , and the wings Pug do now are different. The hole has moved.
£150 is retail i think ? Or even more maybe ? I only paid £95 plus vat i think
