si-mi16
Help With Mi16 Not Starting!
si-mi16
hi all, i have a problem with my mi16 starting,got spark got fuel.
turns over fine and got it to fire up once but as soon as i applied throttle to keep it running it cut out(maybe gave it to much air)
haven't been able to get it fired up again so have given up for today.
What am i doing wrong?
Also anyone in the tamworth or surronding areas that think they can get my pug running, il sort you a good drink out,anyone willing to help
col16vt
hi mate may sound stupid but have you checked ign timing and cam timing
Cameron
Have you just done the conversion or has it been running before?
GLPoomobile
AFM mounted the right way around? Schoolboy error known to happen.
si-mi16
has been running before i change the head gasket :)
i changed most parts while head was off the cam belt seems fine as i have had it start briefly and turned it over by hand a few revolutions and timing looked spot on.
i think its purely down to the ignition side of things, but am not sure of how to go about sorting this out
check the ecu temperature sender.
si-mi16
dont meen to sound daft but where and how do you meen check the ecu temperature sender
Edited by si-mi16
dcc
It is on the thermostat housing. blue plug, screws into the block. should have a blue plug on it anyways! (make sure you dont have the black plug on it which is meant for the SAD from the 8v!)
philfingers
check you're ECT using the PDF attached. As DCC said it's Blue and uses the blue plug
Phil
ECT.pdf
si-mi16
so would this sensor effect the starting of the car or the running??
steve@cornwall
Won't start if not connected - will fire a bit then drown in fuel (not just flood :wacko: )
On Jetronic 8v management this sensor would do that, but on 16v Motronic the car will still start and run, and put the engine management light on.
si-mi16
so what does this sensor look like again and where is it located and where should the cable from the sensor be going to??
sorry if i seem abit simple just havent sen this or heard of this before
sorr
Double check you do not have an air leak, I had the same symptoms and I had not put the pipe on the throttle body correctly :wacko:
si-mi16
its one r1 bike carbs, dont think its an air leak though as when it did briefly fire up i applied some throttle and it cut out :rolleyes: ,will be taking a look at this sensor this week sometime try find out this on going problem. good job this car isn't my daily drive. i've gone german for that :o
S@m
My Mi ran even when the ECU temp sensor was buggered but was severely overfuelling, failed the emissions test in style anyway! But i cant see how it would stop it starting, surely if you read the error codes off the ECU it will come up?
Talk about missing out a vital piece of information in your description of the problem. Ignore the blue sender it has f*** all to do with this now.
si-mi16
opps my bad :unsure: , thought i did mention it as i do in most of my post, so if this blue sensor is not needed then what else could be the cause of my car not firing, just to make people aware the car is as standard engine wise apart from being on yamaha r1 bike carbs and 8v loom/dizzy convertor
S@m
Yeah, kinda missed a trick there, sorry bout that. Just wondered, what condition is the ignition amp in? and is it a dreaded intermotor part? They are pretty sensitive things, a bit of water, or a lack of thermal paste on the back can stop an Mi starting.
si-mi16
i have checked the wiring to the ignition amp and all seems well, where and why does the ignition amp require thermal paste as i have not known about doing this before on previous cars(non peugeot), sorry if a daft question new to the mi16 world
dcc
Its to help the transfer heat from the amp. can only compare it to a computer cpu using a heatsink without thermal paste (pointless basically)
S@m
You can get it from most computer shops, made a difference on mine anyway. Also i have tried brand new intermotor amps in the past that dont work straight out of the box, whereas a dirty second hand bosch one that was (and still is) fine.
si-mi16
ok thanks guys, so guess im on the look out for a second hand bosch ignition amp!
whats a good price i should be looking to pay for a second hand ignition amp then guys?
dcc
£10-15
they pop up on the bay quite often.
si-mi16
thank you mate, have found one on the bay will be buying it the weekend
