jeeves
Sd Roll Cage Fitting
jeeves
I was just wondering if anyone has advice on cutting holes in the dashboard so that a SD cage will fit. I have a ph2 dash and it looks to me like the cage will go through the side blower vents??!! :wacko:
Cameron
If you're planning on driving it hard enough to warrant a roll cage then you don't need a dashboard. Get rid of it. :wacko:
GTI6BOY
10point goes through the dash...6 point does not
jplautomotive
i got full custom cage and that goes though the vents , but mine is not cut very well . is a pain trying to work out where to cut , i could do it better now i no where not to cut lol
jonny
Cameron
Always the way though.. fitting a roll cage for the first time is a very steep learning curve! I managed to do this on my first attempt at front triangulation.
:blush:
Easy fix though. ^_^
Edited by Cameron
DanteICE
jonny
Any pics?
Geoff
jplautomotive
Any pics?
Geoff
no car at my yard will take for you tomorrow
The heater vents and slightly beyond, best bet is to suck it and see so to speak.
jeeves
Ok cheers for your words of wisdom guys. The cage is a SD 10 point and has been fitted for a while i am just converting my dash to ph 2 but because the ph1 dash was done by someone so badly I was just looking for some advice. It will be good to see some pictures if anyone has any??!!
jplautomotive
like i said i could do it better now i no where no to cut lol
DRTDVL
I'll get a nic pic of my dash if you like...
The ends have been cut completely and remounted to fit inside the cage. I do have window gussetting so ya...
