Disclaimer: Although we've made every possible effort to ensure the data on this page correct, we cannot guarantee it is.
Note that the engine number is on a riveted plate on early XU engines as shown in the diagram below.
However on later engines it is stamped on a machined surface at the flywheel end of the front of the block.
If you can't see the image above then you haven't got Flash player.
